use [ble-data-export-policy
|database-policy|license|nsight-policy|
rtl-server-policy|sensor-policy|smart-rf-policy|wips-policy]
use [ble-data-export-policy <POLICY-NAME>|database-policy <DATABASE-POLICY-NAME>| license <WEB-FILTERING-LICENSE>|nsight-policy <NSIGHT-POLICY-NAME>| rtl-server-policy <RTL-SERVER-POLICY-NAME>|sensor-policy <SENSOR-POLICY-NAME>| smart-rf-policy <SMART-RF-POLICY-NAME>|wips-policy <WIPS-POLICY-NAME>]
use | Associates the following policies with the RF Domain: ble data export policy, database policy, NSight policy, sensor policy, Smart RF policy, WIPS policy. It also applies a Web filtering license to the selected RF Domain. |
ble-data-export-policy <POLICY-NAME> |
Associates a BLE data export policy with this RF Domain
database-policy <DATABASE-POLICY-NAME> | Associates a database policy with the selected RF
Domain
Note:
This feature is not supported on the AP5XX model access points. |
license <WEB-FILTERING-LICENSE> | Obtains the specified Web filtering license from the adopting
controller
nsight-policy <NSIGHT-POLICY-NAME> | Associates an NSight policy with the selected RF Domain
rtl-server-policy <RTL-SERVER-POLICY-NAME> | Associates an Real
Time Locationing (RTL) server policy with the selected RF
Domain
sensor-policy <SENSOR-POLICY-NAME> | Associates a sensor policy with the selected RF Domain
smart-rf-policy <SMART-RF-POLICY-NAME> | Associates a Smart RF policy with the selected RF Domain. When
associated, the Smart RF policy provides automatic recovery from coverage
loss (due to failed or faulty radio) by instructing neighboring access
points to increase their transmit power. Once correct access point placement has been established, Smart-RF can optionally be leveraged for automatic detector radio selection. Smart-RF uses detector radios to monitor RF events to ensure availability of adequate detector coverage.
Note: SMART RF is only applicable on AP510i/e and AP560i/h functioning
in the dual-5GHz mode. That is, on the AP, RF mode for both radios is set
to WLAN-5GHz.
wips-policy <WIPS-POLICY-NAME> | Associates a WIPS policy with the selected RF Domain. A WIPS policy
provides protection against wireless threats and acts as a key layer of
security complementing wireless VPNs, encryption and authentication. A WIPS
policy uses a dedicated sensor for actively detecting and locating rogue AP
devices. After detection, WIPS uses mitigation techniques to block the
devices by manual termination, air lockdown, or port suppression.
nx9500-6C8809(config-rf-domain-default)#use smart-rf-policy Smart-RF1
nx9500-6C8809(config-rf-domain-default)#use wips-policy WIPS1
nx9500-6C8809(config-rf-domain-default)#show context rf-domain default contact Bob+14082778691 timezone America/Los_Angeles stats update-interval 200 country-code us use smart-rf-policy Smart-RF1 use wips-policy WIPS1 sensor-server 2 ip 172.16.10.3 override-smartrf channel-list 2.4GHz 1,2,3 override-wlan test vlan-pool 2 limit 20 layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters nx9500-6C8809(config-rf-domain-default)#
no (rf-domain-config-mode) | Removes policies associated with this RF Domain |
